I am making a set of rocket fins for a pretty serious project. I have just finished the two part mold and would like to attempt to infuse them.I’m hoping to use a unidirectional carbon fiber in the layup for the most part. I plan to add a couple pieces of a weaved material to help the resin flow through the uni because I’m thinking the uni itself may not infuse well.
As I set this 15"x15" project up ,I hope to produce some pics and get some advice in regards to setup.
The laminating epoxy I normally use is Resin Services HTR212 with 386-99 hardener.
A couple questions:
Could anyone recommend a good high performance epoxy with a fairly high Tg ,say 300 degrees or higher that will have a low enough viscosity to infuse?
And could anyone give me there thoughts on infusing Unidirectional carbon?
Thank you,
Terry
