Hello,
my name is Dominik Dierkes and I found this forum because my video has been linked in one of the threads.
We are a German company which has developed the MTI hose. MTI means Membran Tube Infusion.
The MTI hose is an evacuation hose for the vacuum infusion. It is air permeable but non permeable for resin. When resin reaches the membran it will stop there and will flow through the dry rest of the fabric. Thus cost intense and complex calculations of resin injection points are redundant. By using the MTI hose the complete impragnation of the fabric is guaranteed. The resin allocation can be arranged independently from the MTI hose, so it is possible to manufacture complex fibre parts by vacuum infusion. The MTI hose can be located directly on the fibre part, e.g. at critical points or fields with material accumulation (thicker layers).
The fibre to volume ratio can be exactly calculated, because no resin can discharge the mold. An additional advantage; the infusion process is visible and can be monitored at any time.
This process qualifies for small fibre parts and single piece production as well as for big fibre parts and serial production. The MTI process reduces costs while increasing the quality. The MTI process is suitable for conversion of production from hand lay up lamination to vacuum infusion, because for using the MTI process no molding lips are necessary. The MTI hose can be located directly at the edging of the fabric, thus conventional molds can still be used.
Advantages of MTI hose:
> less effort for preparing the infusion process
> no resin trap necessary
> few investment cost
> visible infusion process
> minimize of resin consumption
> resin allocation independend from evacuation hose
> small molding lips
> reduction of Dry Spots
> more process stability for single piece production and small series
> minimize material consumption
> high fibre to volume ratio, adjustable through injected resin volume
We made a video of manufactoring a part. The video shows the effect that when resin arrives at the MTI hose i will not get in it and will further flow through the part.
[ame=“http://www.youtube.com/watch?v=aF3ll_h9EAw”]MTI Membran Tube Infusion, resin infusion, vacuum infusion - YouTube[/ame]
[ame=“http://www.youtube.com/watch?v=8lKabpAMluk”]How the MTI hose works - YouTube[/ame]
We tested the MTI hose with VE, Polyesther and Epoxi. All tested resins worked.
The MTI hose is also very interesting for people who want to try producing parts by infusion.
I send a sample to some of you and hope that you will test it. May be you can write your experiences in this thread.
If anybody else is interested in our product I can send a sample, please contact me via PM.
YOU CAN FIND YOUR DISTRIBUTOR AT www.dd-compound.com
Regards
Dominik
