what is casting resin?
and how to use it? any advise please?
Casting resin is to cast things. How to use it? Mix resin with hardener, then cast.
the slightly more technical way to say that is that the resin is crystal clear, and is designed for casting objects into it. Think paper weights or the trinkets like scorpions in globes.
It usually has a slight thickening agent in it, making it tougher to work with in some aspects if you are wanting to use it as a surfboard type lay up resin.
I wouldnt use it unless you are using it for casting objects or start with experiments that dont matter.
mixes the same as most resins…2% catalyst by weight.
i mean what to lay on carbon part so surface be scratches resistant like from china very hard surface so we not get they polish reson or what they do on last top coat.
Automotive car paint.
You want to cover the surface of the carbon part with casting resin instead of clear coat? I don’t know if casting resin can cure in thin coats as it is mainly for casting in silicone molds.
as i do not know what chinese resin can use as what i touched their parts very hard surface even to scratch.
