So I’ve been having a few slight problem with slight delamination with Duratech’s new top coat and VE resin.
My process is spray a mold with about 18 mills of Duratech’s new top coat. Let it cure, then laminate with carbon fiber and infuse with a layup VE resin. I do use a little super 77 but I have never seen this problem with other gel coats like clear marine gel coat.
I catalyze at 2% and let it cure for at least 6 hours before I demold, sometimes I demold after 3 hours if its a two part component where the two halves prevent each other from warping.
Here is an image of the slight delamination. The highlighted spots on the top of the carbon tows are the problematic area, never the low points in between the fibers where there is more resin.
Theories - resin starvation on some of the fibers? I say that because the intersections don’t show signs of delamination. The intersections are where there is more resin mass because for that 1mm x 1mm area there is no fiber.
Another theory is I’m allowing the top coat to cure too long. I understand that its a high solid top coat, meaning non porous. Any thoughts? I usually don’t infuse for 12 - 36 hours.
Last theory is cohesion. I doubt there are cohesion problems because I’m trying to laminate carbon with VE resin over poly resin. However I have had worse issues with a VE / Poly blend infusion resin.
Possible solutions?
Maybe allowing full cure and sanding with a 3" orbital sander to 320. But then I’m relying on a mechanical bond, not chemical, right? Or would I still get some chemical bond since it would be less than 36 hours.
Ideally I want to infuse after 4 hours, but when I get some fish eyes I have to drop in duratech and then sand it later, and I can only sand after 12 hours of curing.
