Im looking for a resin system for making “inhouse” prepreg.
Any tips?
The curing temp can not be more than 120 degrees celsius.
I would like shelf life up to 12 months at -25 degrees.
Any ideas?
Is there a sicomin supplier near you? they carry a resin for that purpose. suppliers I know of are in Belgium/Netherlands and Germany
Only resin system that I know is available in smaller quantities is Sicomin SR8500 and SR121 with curing agent KTA21.
This at least is available in Europe, but I believe Norway does not have a Sicomin distributor.
I actually have it available in small quantities, and can send a datasheet if you like. As your post count does not allow private messaging, you can mail to hb at brandscomposiet dot nl
Thank you for the tip! I dont think there`s any supplier in norway.
Great! I will send you an email.
hello to you can you to israel the sicomin i realy realy need it
thank you
Anyone know of a similar resin in the US?
I can see one here:
http://www.fibermaxcomposites.com/shop/-p-1058.html
But do not know where they are from, does anyone know this resin?
