okay i have a headliner i overlayed… and this is the first “large” part i have done…
after the saturation coat i let set. went to work on the road came back in one week and applied a second coat… this coat is pooling even after i squegeed off excess. then let that set up and applied another coat and it helped a little with the pooling…but not like i would hope…
its almost like the resin doesn’t want to bind to the part correctly … and just keeps coming together on itself…
(laminating resin 1/1 mix)
how do i get the resin to lay flat and not have a texture… (not the weave texture… an up and down texture… high and low )
help/ advice
