I actually have three problems on complex forms with infusion process.
To positioning the fabrics, it’s hard but it’s not my main problem.
The problem comes from the peel ply. The peel ply does not stretch as the carbon fabrics.
1/ I put my peel ply with multi parts but I always have strenght on it on the complex areas. This makes some holes between my in mould coating and the first layer.
What is the best way ? Should I put more parts of peel ply or should I make some plies to reduce strenghts ?
If I make plies, I make and excess of resin …
2/ The finition on the rear side is not as beautifull as I want. It’s really hard to pull off the peel ply with multi parts. I have some yarns of pleel ply.
3/ I have an other problem on concave corners, my film doesn’t go as well as I want. I have an excess of resin and I cant pull off the peel ply correctly.
For my first and 2nd problem, is there an alternative to peel ply for infusion process ?
For the 3rd, is the best solution for complex part is to use vacuum film like Strechlon ?
I ever try this product but I never arrived to make a good vacuum with it, really strange …
A picture of the type of part that I make, on top it’s prepeg, on bottom my infused part:
