Prepreg:
+No impregnation needed.
+No postcure needed.
+Selectable tackyness.
+No dry fibres in the air.
+precision placing, limited deformation of weaves.
+no pressure pot, no filled up lines
-limited out life.
-high temp moulds.
-Preferably computer controlled oven for optimum accuracy needed for good finish.
-debulking on thicker laminates
Infusion:
+No high temp moulds.
+more flexible in the use of materials.
+no debulking.
+no sticky pieces of frozen resin on the floor, which keep on sticking for weeks, and then are hard to get of.
+Impregnate yourself, correct amount of resin, without separate glue films, etc.
-Seperate post cure to prevent print/deformation
-Impregnate yourself, extra work.
I must have forgotten a few, who fills in the gaps?
With vinyl-ester a post cure isn’t always needed, less expensive, less sensitive for UV. I think with vinylester your better off infusing anyways.
