I have been asked to make some rather large flat panels of prepreg and nomex honeycomb. The panels are 70" long and 35" wide. I typically use polished aluminum plate for this type of work, but the largest plate I have is 36"x30"… Question being, any reccomendations for a large true layup surface for a reasonable cost?
The only thing I am coming up with is holding down a sheet of mylar to flat piece of MDF, and then covering the whole thing with high temp tooling gel, then lay down some glass, honeycomb core, more glass and then maybe some angle aluminum to support? Does anyone have experience with that - I fear the thermal expansion on the aluminum will cause problems, but I have never tried. Any ideas are welcome! Thanks
