I pulled a part from the mold today and it turned out pretty good other than what I think might be adhesive spray residue on the surface.
I used a new product from 3M “11095 Adjustable Composite Positioning System” I used very little and these specs seem to coincide with the same amount of product I sprayed into the mold. I think after I wet sand the part with 800 grit and clear coat it won’t be noticeable although still a letdown to have a surface that isn’t smooth and glossy from the mold.
What do you think it is? I hope you can see the pictures.
Sorry for the different size text I can’t figure out what caused it and I can’t seem to fix it.
