i have been experimenting with infusing goalie masks. i have a fiberglass female mold and a silicone male mold, and a plenum ring which goes on top to seal the too together. i have no problem getting 28+" vacuum. the problem that im having is that my parts are delaminating on impact.
i am trying to infuse carbon and innegra but when i infuse fiberglass i have the same problems. i have tried normal iso infusing resin, derakane and cray valley vinyl, and cass epoxy. i have the same problems every time no matter what the resin is. i also have the same problems irrespective of how much resin i use. (i know it sounds weird but i tried putting 1500 grams of resin in for 350 grams of fabric and i still had same problems.)
i calibrated the molds with 2mm wax, and my part is 3.5mm thick. i thought that perhaps if i calibrated it differently the problem would be resolved but when i calibrated it with 3.5 mm wax i still have the same problems.
i have tried coremat and veil as vent tabs as well as bleader as vent tabs and still the same problems. i have used as few as 2 and as much as completely surounding the permimeter and still have the same problem.
hopefully someone with some experience with infusion could give me a hand. im sure im just missing something small here.
thanks…
Gabe
