Hi, I’ve been searching all over the web for the answer to my question with no results, so I’m posting here in case someone can help.
My idea is to have an alternative to typical 30% glass filled nylon, which is tough to get in my country and besides needs a molding machine. To be used in prototypes which must be functional.
I would like to use glass filled or carbon filled epoxy, about 1/4 to 1/2 inch strand size for the filler and mixed with epoxy at any suggested weigh ratio. Ideally 1:1 by volume, if possible or more.
I could even mix as much filler as possible, fill an open mold and apply vacuum to remove excess epoxy. And finish the top of the part by machining.
What minimum mechanical properties can I expect? Would they at least match those of common nylon without glass reinforcement?
Thanks for any help and alternate ideas.
