I have a a few questions regarding flow media. i have a small petrol cap mould and i am having problems with bridging. but is not the bag which i first thought.
my pleats are ample so my question is do i have to put flow media over the full surface. i am going to be cutting it in peices and putting more than one single peice and probably doing the same with peel ply,
also can i ask how many people spray epoxy gel coat onto there moulds because i am bit wary of using spraying 3m glue onto the surface of the mould as would like a perfect sureface
and if you do spray the epoxy in how long before it goes off??
regards
