Thank you.
Adam, ouch that DC3000 is pricey. Re: Klass Kote… They seem to have epoxy paint, and urethanes. Do you mean Klass Kote Epoxy Clear #40, or do you mean Klass Kote Urethane Clear?
But now I have a stupid question… If I’m possibly putting epoxy into the mold, why not just use my same infusion epoxy? Then infuse it the next day, or is that the point, it eats a day?
-Joe
I only used Klass Kote colored epoxy paint. I’ve never tried the clear or know how it performs in respect to UV.
I pulled my first test part using a 2k clear coat urethane this morning.
Aside from known scratches and goobers in this old test mold, the part is absolutely perfect! Thank you Adam!!! For the first time I feel some competence in what I’m doing! :D:D
Hi Adam,can you please send a picture/link of the IR lamps you’re using.
thanks
thanks, where can i easily get these?
Honestly, I’m not sure. I got mine used from a local paint shop. Either they were going out of business or were upgrading…I can’t remember.
Check out your local NAPA auto paint store, I was in my local store yesterday and they had then on the floor.
Jon
At what point can you start an infusion after the clear is sprayed into the mold? Does it have to be tacky or can it be fully cured? If fully cured, do you need to scuff up the clear so the resin can bite in ?
I like to the let the paint set up pretty hard. I’ve never had bonding issues…but I use epoxies. I cannot comment on how PE or VE stick to cured 2K clears.
is 2k short for klass kote or a different brand? can someone link me to a place for the 2k clear you guys are talking about?
2K = 2 pack, 2 component, as in: base material + hardener.
hahaha duh. what brands do you guys recommend for the 2k urethane? (can this be brushed on?) I will be using it for car parts so I’m looking for something with good UV protection… ive heard deltron 3000 thrown around in various threads… anything else i can get a local auto store?
I have been in the auto industry for years and am just getting into the carbon/epoxy world…
so I get all the ppg light coats tack off stuff…
What kind of mold release are people using with the 3000 clear and has anyone tried DCC concept in the mold…
I used a frekote the first time and it fisheyed like crazy… I didn’t mist it and let tack enough I guess…
I have tried a few different mold releases in the sprayon line like the s00315 urethane and styrene silicone mold release…
Has anyone tried a fisheye eliminator in the clear… It has been years since I have had it around and I might not be the best additive…
thanks for any info
