I have a couple of plugs that were built using foam, fiber glass & epoxy. The current surface is epoxy/microballoon sanded to 320 grit & fully cured at room temp. Will Duratec Surfacing Primer adhere to this surface if sprayed on? Is there a barrier layer I should apply 1st that will ehance the bonding of the Duratec to the epoxy base?
Or…
Is there another epoxy compatible surfacing material that can be sprayed, sanded & polished to a class A finish?
The molds built from these plugs will have an epoxy tooling coat as the 1st layer if that makes any difference.
Bob
