I have been taking a bit of a look into the homebuilt aircraft community, I have found some interesting ideas and picked up some good tips from what I’ve been able to find so far.
More interesting is the idea of low vacuum bagging. I just wanted to see what people’s thoughts are on this: http://www.cozygirrrl.com/lovac.htm
To summarise some of the benefits:
[ul]
[li]No bubbles or air
[/li][li]lighter parts
[/li][li]highly conformal lay-ups on complex parts with sharp edges and tight radius edges
[/li][li]Most importantly - minimal cost in disposable supplies
[/li][/ul]
They do say that this is only suited to make some conventional lay-ups better, so it’s not an option for certain parts, and not an all-inclusive solution.
Basically the idea is to use a low vacuum pump, they use a linear piston machine that pulls maximum -9.84 in.Hg at 7L/min. They use a ShopVac to pull the majority of air out before attaching the LoVac.
Also on the consumables side - it looks like they use pallet wrap instead of any kind of vacuum bag, and instead of breather they use… paper towels! So yeah, they’re not spending much on consumables!
Another important point is that they use a slow cure epoxy which is warmed so that it flows really well and is thin.
From what I can see, they remove the vacuum once it gets to the green stage (after the “chewing gum” stage) and then remove the paper towels while they still come off easily.
So - for a low cost home DIY solution, it seems fairly good to me.
I’ve seen mention of a linear piston vacuum pump here before, and after looking into it some more it seems like a really good option for vacuum bagging. There is a more powerful -23 in.Hg model that I have seen for $80 plus shipping, I’m wondering if that would do an even better job? The larger pump may be suited to a more “traditional” bagging method, though I’m not sure how that would go if the paper towel idea was used?
I’m interested to hear what you folks think about this? Or even better - has anyone tried the LoVac method?
