I completed my third vacuum infusion for a project I’m working on and I’m quite pleased with the results… For this particular project, the side of the CF stack that I’d like to show off (clear coat & finish to a high gloss to show the CF 2x2 weave) is the side next to the consumables. In other words the surface that I’d like to finish to a high gloss had the red stripe peel ply against it thus the CF has a textured surface. Today I lightly sanded with 220 grit paper and noticed a good amount of black carbon dust… it was then that I realized sanding might not have been the best idea. I’m thinking I should have cleared right over top of the peel ply textured surface and then sanded the clear coat instead. That said, what brand/part number (be specific) clear coat do you guys recommend. What process do you recommend to finish the textured surfact to a high gloss? Can I clear right over the CF even if my light sanding exposed some of the fibers? (please be specific as I’m a newb). Note that the CF surface will never see direct sunlight so I dont beleive I need UV protectant clear coat… or do I??? This project is for the inner wheel wells on an experemental aircraft… the aircraft will eventually be painted with Imron 3 stage paint so I’d like to use a compatable clear coat if possible (or maybe I should be using THE very same clear that I will be clear coatig the aircraft with???) … Any advice you might be able to offer will be greatly appreciated!
Thx!
James
PS… I’ll post some pics tomorrow…
