Nice piece of art. I guess the rim is basicly a tube. What kind of fiber did they use? It looks like a cut up piece of biaxial?
The visible part has a piece of woven carbon on it. I guess it is all prepreg, so they could have applied it on the mould before winding.
2 things still: The spokes are bolted on. Of course this is not ideal, but seemingly it works.
Second, contradicting point 1, is that when braking, enormous amounts of heat are generated, and dissipated through the wheel. The wheel acts as a heatsink.
I have been supplying a Dutch company making truck wheels (50 lbs for a double-width wheel, a so-called “super single”). Their biggest problem was the heat. They used a $30/lbs epoxy resin to infuse the wheel, with a Tg of over 175 degrees C, but that was not enough. Brakes generated some 520 degrees C after 2 emergency brakes one after the other.
just finished is the “Superbus” which is a bus, capable of doing 250 km/h (150 mph) also with composite wheels. I warned them for the effects of an emergency stop, but we will see. (for now there is hardly any road that can house the thing. 12 meters long, ground clearance of 3" tops.)
My guess is that these wheels for now are more show pieces than for racing.
