I’ve seen alot of guys talking about making carbon fiber tubing but, no one has really explained how to go about doing this. I have red about the bladder (which I have no idea what that it is) and wrapping carbon sleeves around the bladder.
My question is what is a “bladder”? What do you fill the bladder with to get the shape, dimension and bend needed? How do you conform the bladder to the bend and dimension that is needed? Is a mold needed to conform the bladder and then the carbon sleeving to meet the dimension and bends that are needed?
Also, I have read about the heat issue with turbos and superchargers. What type of sleeve should be used and what type of material should be used? Should the sleeving be vacuum bagged when setting up?
