I have posted this question also on a longboard building site. Any help would be appreciated:
I want to fabricate a CF / foam core 46" pintail for my 16 y/o 105# daughter. I have some basic experience with CF wet lay up and vacuum bagging. I’ve previously made a BB core CR/Kevlar pintail and a full CF foam core skateboard off a gelcoat mold made from a bare skateboard. I used coremat foam which is a mistake as it is a resin sponge. I now have good double cut 1/4" Corecell 500 foam
I’m familiar with the basic techniques. I need advice from experienced CF fabricators.
(No, a 16 y/o does not need a CF composite board. It is a hobby. I like doing it and I want to make it for my daughter. )
I have a number of different fabrics available and she has her specific requests so some of the material choices (she likes texalium)will not make sense from a structural standpoint.
I want to fabricate a Texalium/3k towCF/Corecell 500 pintail, West systems 105/207 resin, wet lay up and vacuum bagged. The pintail “donor” board which I will make the gelcoat mold is moderate concave; neutral with regards to camber/rocker. In the area where the trucks are mounted the foam core will be cut out and replaced with a “forged composite” plate of the same thickness as the removed foam (“forged composite” of chopped CR and resin pressed and vacuumed.)
Questions:
Is this board too long for her 5’4" 105 # frame. She is a relative novice.
Should I use one layer of foam or stack two.? If I stack two should I put CF between the two? I’m concerned that one layer will be too thin and lose the stiffening effect of wider spaced CF. I’m equally concerned that two layes of 1/4’ foam will be too thick and therefore too stff. I have no other size foam available. This leads to question 3, number of layers and foam core:
Foam and layers, options A, B, C
A. Tex
CF
0.25" Corecell
CF
Tex
B. Tex
CF
0.5" Corecell
CF
Tex
C.Tex
CF
0.25" corecell
CF
0.25" corecell
CF
Tex
C is thickest and stongest. But pretty thick overall compared to a wood board.
- I have researched many foam cores. Is Corecell a good choice?
- How much does concavity add to board stiffness?
- Do i need to reinforce the truck region with forged composite as I have noted above? I’m concerned that the corecell will deform or delaminate at these stress risers.
- Is this a enough CF considering I’m using texalium? (only four or five total layers)
- Will texalium conform to the mold with vacuum bagging? It is super stiff even before lay up. The corecell is stiff as well. If I cut the corecell well enough, can it function similar to a caul plate and aid in reducing voids?
I appreciate any suggestions.
