So my partner, (business partner… Not that theres anything wrong with that.) And I are making a mold for the radiator cover of the 5th generation Camaro. I’m documenting this here to share our work and hope some of you can input some words of wisdom since we are aiming to make a perfect mold. Most of our molds before were just, “good enough” but since this will be a difficult product to sand and polish. We are looking to make the mold perfect to minimize post work.
We are starting it by filling all the holes and negative areas on the part by attaching the part to a 4ft x 2 ft piece of Formica board. We will the fill in the gaps with joint compound and sabdable putty. Once that is finished we will be priming the plug with Duratecs 707-002 gray surface primer. Once that us is cured we plan to wet sand, buff, and polish the entire plug.
After that is done we will be trying something new, and here is where you guys come in handy. We were told to clean then degrease the plug, wipe on several coats of chemlease #15 sealer, let sit, then wax the plug several times with Rexco’s mold release wax.
After that can we skip pva and go straight to gel coat? I’ve been a sissy the past 5 years and never wanted to skip pva because I’m always scared that the resin over the mold, (or plug in this case.) Would lock in and destroy both parts.
Now I’m aware that the chemlease #15 is a sealer but is it classified as a semi perm release agent? Or only a sealer?
I ask all this because we want a glass like mold surface with out having to go through hours of wet sanding, huffing, and polishing… I realize sometimes that’s the case, but idea seen many people make molds on YouTube with out pva and they come out beautiful.
Lastly, I’m using a red tooling gel coat as the coating and then it will be reinforced with 8 layers of 1.5 oz chopped strand matt. The resin ill be using will be an isophthalic PE tooling resin with a HTD of 210. Do I need to post cure that or can it be cured at room temp or a slightly elevated temp. Maybe 100f. I usually just let the mold sit.
Here are pictures of the progress thus far.
dnt forget when sanding you also remove micron
