New user here.
I have a couple questions. All the products I have been using were ordered from fibreglast.com, except for the fabric which I got from AVT…
What is the best way to work out the bubbles and voids in a wet layup (6oz CF Twill in Polyester resin with a clear gel coat)? The last time I tried, I had pretty good luck with spraying the gel coat, letting it get tacky, then brushing in the PE resin with a bristle brush, placing the fabric, then applying more resin with the brush, then vacuum bagging. However, there were still some very small bubbles. Hardly noticeable, but I’m a perfectionist I guess. Another drawback was that the vacuum bagging seems to have distorted the fabric a little bit where it was pressed up against the gel coat ‘orange peel’ texture. Any tips? Is there some type of squegee or roller I can use to work out the bubbles? Yesterday, I laid up another part using a little different technique. This time, before placing the fabric, I painted some resin onto the gel coat. Then I laid out the fabric on a sheet of vacuum bagging material and brushed the resin into both sides prior to placing in the mold. Once in the mold, I placed the bagging mat’l over it and used a plastic squeegee to try to work the air bubbles out to the outside of the mold. Don’t know if this was successfull yet - I will be releasing it from the mold tonight.
Is there an epoxy surface coat that is clear? If not, would a polyester gel coat bond to a part laid up with epoxy? I’m thinking about using the clear pe gel coat as a clear coat for UV resistance. Spraying it into the mold first, and then laying up with epoxy. Would there be a better approach?
What epoxy resin/hardener combinations is the most clear (I.E. least amber tint)?
Thanks so much for your help. I’m just getting into the industry and can use all the help I can get!
Sincerely,
Jeremy
