raises hand
I have worked with Kevlar/PP sheeting from Polystrand. The material is a board like material, maybe 30mils thick. Will NOT shear, meaning flat panels, or thermoformed into easy shapes. Also, I have worked with SpectraShield, which will shear maybe 1-2%. It is 30x harder to cut, and like many thermoplastics, is hard to weld together to hold shape.
On other materials, spectra that was braided with TPU and LDPE, S2 and Kevlar with PP, ceramics of sorts, S2 with PA6 as well. Also, a fun new material called Vectran used with PP and PA12a.
There are many S2/Kevlar with epoxy armor apps, and many more with thermoplastics. It all depends on what you are needing.
I think for soft armor, the kevlar is stitched in a quilt pattern. It also apparently can be sheared at 45deg to original 0/90, and that holds the impact load more in plane, and still is very drapeable.
For fuel tanks, I know many places will use a hardarmor, and then line the inside with a self-healing rubber, so even if there is penetration, it will not leak all over.
On avg, most ballistic panels out of kevlar/S2/Spectra and using thermoplastic or thermoset, seem to be from 3/4" to 1.5" thick to have any good V50 ratings using rifle rounds. Standard handgun ratings I do not know. I’m sure not as heavy duty as rifle.
