Hello,
I am making some large diameter tubes using prepreg carbon fiber. I’ve previously used wet layup to make these tubes and handling the large pieces of cloth required to make the tubes (22" diamter x 60" long) was a pain on multiple levels. I am considering using 3M 77 to tack the prepreg (on the dry side) in place while I lay up the part.
The cure cycle for my prepreg is ramp up, 250 F for 60 minutes, ramp down. I am concerned about outgassing from the 3M 77 causing problems.
Has anyone used 3M 77 in a prepreg process?
Are there spray adhesives specifically made to tack epoxy prepreg fabrics?
Thanks!
Dave
