I need 5-10 yds. of Advanced Composite Groups LTM 24 SD in a 2X2 twill. May be interested in some other low temp pre-preg in a 2X2 twill weave. Please let me know if you could help.
Thanks, Ro Yale
[QUOTE=Ro Yale;36115]I need 5-10 yds. of Advanced Composite Groups LTM 24 SD in a 2X2 twill. May be interested in some other low temp pre-preg in a 2X2 twill weave. Please let me know if you could help.
Thanks, Ro Yale[/QUOTE
Did you try calling and asking for sample?
A sample would not be enough. They would only sell a roll for about $6500. Just can’t see doing that for a part or 2.
You could make your own pre-preg, that fabric you mention is just a single sided prepreg twill right?
Lay some fabric out, pour on the epoxy and squeegee the epoxy out, lay some film sheet down over-top, roll it up and toss it in the freezer.
I’m really trying to control the fiber movement. I can control it when I start with dry fiber but it’s not perfectly aligned. Not like a prepreg from a reputable manufacterer. My customer wants perfect alignment of fibers. I can do some nice work but when you see it at some angles the fibers aren’t perfect.
Whoever there that gave you that price is a complete nut. I can tell by the quote that they gave you that for one you never bought from them and for two they didn’t want your small sale. There known for doing that. Sorry that they did that. Let me call my contact there and see what i can do for you. It will probably lead to nothing but it’s worth a try.
Have you tried fabrics with a binder?
Susho,
No I haven’t tried the fabrics with binders. I did order a few meters today but they don’t have the width that I really need. I just ordered some to experiment with. Do you know where I can get some fabric with binders that is 1.2 meters or more? Thanks!
Only found 1 mtr wide.
Hey ro yale. Called my contact there and unfortunatly he doesn’t have any standard resin weight ltm24st in his stock. All he is doing is experimental stuff at the moment and is not sure when he will be getting any stock material into his freezer. He said he knows the stock freezer is full of the stuff but he can’t go in there and just cut off a few meters unfortunatly. I told him to give me a call if any of the stuff in the stock freezer expires soon and to save it for me.
