So much for a write-up since the thought of taking pictures during the process never even crossed my mind. Then again, I would not want to encourage copy cats.
So I made my 90 degree angle flange all around the plug using modeling clay (the kind that does not dry). NOT EASY. I need to figure out a better way next time. I don’t remember how long this it took since I did it over a course of 2-3 days.
Now to the mold making part. I got some orange tooling gel as my gel coat for the mold’s surface. This is a polyester gel coat so I added the recommended amount of catalyst and applied my first coat over the plug. I waited for about 20-30 mins and repeated the proces. I did a 3rd coat just to be sure it’s thick enough.
Now it’s time to apply the glass backing. I ran out of glass so I just got whatever that stuff they had at Home Depot. $5/package of 9square feet of woven glass. Seems like it weights about 2-3 oz which is kind of light. I used up about 3 packages. I chose to stick with polyester resin for this process since my gel coat is also Polyester.
A day later. Now it’s time to remove the mold from the plug. Crossing my fingers hoping that there’s no bubbles/voids on the surface of the mold. The mold came off very easily thanks to the wax and PVA. The surface looked very good except for minor hairline cracks and whatnot.
