I was wondering if any one could provide more information on working with a urethane for body parts. How it would work when using it in a mold.
The only Polyurethane body parts I have seen made were injected into a clam shell closed mold. For a wing, a pre formed foam with surfacing veil was inserted first before closing and injecting.
JM
Are you referring to urethane bumpers and stuff like that?
Yes. Which the part we have been talking about is urethane. After I have a mold of the part I would like to make more out of urethane. Which I think would be easier then making them all by fiberglass and would allow them to be more flexable.
It does take an expensvie piece of equipment to mix and pump each of the 2x parts up to the nozzle and then the disposable tip does the mixing.
Evan, I hope you don’t get mad for me posting this company that makes this equipment but they just donated a bunch of 2 part foam (20 gals) and 2 minute PUR casting resin (20 gals) to my class. www.bjbenterprises.com and ask for Tina in sales, tell them “JM” referred you.
Actually JM I do mind. JK. I would have recommended BJ Enterprises too. In fact, I’m all for “BJ” anything in general
Evan, get your stick out of the gutter…it is BJB not BJ: blow Job
:roll:
My bad, don’t tell me you don’t at least think about it every time to see the letter B and J next to each other in that order.
So does any one have more information on pouring this into a mold?
You’d have to inject it. Pouring it into the cavity mold won’t work I don’t think.
There are pouring resins out here but I don’t have a scource. rotomolded fuel cells use it. It is poured into a mold and put into a rolling machine that rolls the mold around until the stuff cures, the mold is open and out pops a cell.
Ok there has to be an easier way then but avoiding a wet layup or vacume infusion for every single one.
What Bricklin is talking about is Rotational molding but they have to use a special 2 directional rotational moding machine that also has a heating and cooling sections.
The fuel cells are molded with HDPE or you can use LDPE or other thermoformable plastics.
So does every one think that I should just vac bag these? I was looking at making a few hundred.
