Hi folks,
I have been working on some custom bodywork for a project bike I’ve got going at the moment. I had planned to do a full writeup here when it was all finished, but I figure that I may as well post it up now as I’m going so that people can follow along and maybe I can get some tips as well if anyone sees a way to do things better…
First up I’ve got to say what a fantastic resource this forum has been… so many knowledgeable and willing people here who go out of their way to share their hard-earned experience and information. Thank you to everyone who shares their knowledge here, just browsing the forum and spending some time learning gave me a lot of confidence to take on this project for myself.
I wanted to try and give something back, so hopefully this thread can give a bit of inspiration to someone who is thinking of doing a small project themselves as well. One thing that I want to show is that you don’t need very much in the way of equipment or tools to get started. This is really the very first composites project I’ve done (I’ve done one piece before which was an attempt at a pillion seat cowl for my Gixxer that was abandoned half way through.) I don’t have a big budget at all, so you’re going to see how far that can take you.
Now let’s get to the details…
For anyone interested in the bike itself - it’s a 1999 KTM 380EXC. I picked it up for a fairly good price, the idea is to build a mega-raging big bore 2 stroke supermoto. There needed to be some work converting it from a dirt bike to supermoto anyway, and for a few years I’ve wanted to do a composites project for one of my bikes - so this was the perfect chance.
Here’s what I started with:
KTM 380 SM 001 by mugget, on Flickr
The bodywork looks a bit old fashioned (well, it is) so I knew I wanted to make something that had a sharper, more modern look. So this was the mockup that I settled on:
KTM 380 SM - Final Body Style by mugget, on Flickr
Not necessarily that colour bodywork… but you get the idea of the shape. My final plan is to have one set of bodywork with visible carbon fibre (yes, that’s purely for the bling factor. Haha.) But before that I’ll do one or two sets of fibreglass bodywork that will be painted (so I have some spares, and don’t risk scratching up the CF panels if I ever take the bike offroad).
The next step was to get a template that I could use to mark out the same shape on both rear side panels. Then I started shaping it up with clay:
Mockup Shape by mugget, on Flickr
The clay kept alright overnight as long as I kept spraying it with a bit of water then covered it. This is basically what it looked like before I put some fibreglass down to start off the plug:
Clay Mockup by mugget, on Flickr
Cutting out CSM and peel ply:
Cutting Peel Ply by mugget, on Flickr
The first side laid up:
Start of Plug by mugget, on Flickr
And yes, that’s peel ply on the top. This was actually a neat trick that someone at the local composite supply shop told me about - if you put peel ply on top it leaves a nice, evenly textured surface that is ready to take body filler etc. And it worked a treat! Just pulled off the peel ply and there was a nice smooth surface, ready to get straight on with the rest of the shaping.
Next up I got to working on the headlight. You’ll notice that the card I used in the side panel mockups was just plain card… which is a bit of a mistake. It absorbs the moisture from the clay and deformed the shape a little bit. So for this I taped up the entire mockup to avoid that problem:
Headlight Mockup by mugget, on Flickr
Headlight - Clay Mockup by mugget, on Flickr
Then I masked up a piece of perspex and pressed out a bunch of shapes that I could use for some test layups.
The Play Doh leaves a certain texture, but that doesn’t matter - the important thing was to learn about the inherent strength in a shaped part, and how different CF/fibreglass layups work. (My plan is for just one surface layer of CF, the rest will be fibreglass with one layer of Innegra.) The pieces with corecell are amazing… I had no idea you could get that kind of strength just by adding a simple piece of foam…! This is good, because my plan is to use the corecell in the rear fender, since it has to support tail lights and a license plate.
