Hi Guys,
I’m doing a little bit of research on preparing four wooden molds (square shaped upside down bowl approx 10" (254mm) on all sides at the bottom - smaller on top)
The molds will be used only once for an epoxy based vacuum bagging operation.
I was planning on:
Sanding/Priming/Sanding/Painting/Sanding/Painting/Sanding
Then follow up with Frekote B15 Primer/Final Sanding and then four coats of 700 or 770 NC release.
For the initial paint layers, I am planning on using some “engine” spray paint that can be picked up locally which is OK up to 500F.
Any ideas if this plan will work? Should I look at some other type paint? I called Frekote and they are still talking to the engineers, so I’ll call them back later this week if I don’t hear from them first.
Thanks in advance,
Dallas
