Hi Everybody
I need to infuse a wingspar and started with a first approach. However that approach was not appropiate because the seam between inner shearweb and outer shearweb wasnt wrapped together. I enclose the setup in the first picture. Its a section view of the spar layup.
Accordingly I tried to arrange the infusion in a way that alowed the inner shearweb to be wrapped around the outer shearweb as shown in the second picture.
In this arragement the infusion is done out the mold. I have one worry. Could it be that the spar flanges are permeable after the first infusion and that i get a vacuum short circuit and consequently the flanges dont wet out correctly?
Do you see any other issues?
Would you bond the rohacell core and poltruded carbon rods with epoxy or methacrilate? Could you think of a weight efficient way to bond them during the infusion and not in a separate stage?
Thanks everybody
