Our state just put up dozens of the giant wind generated electric mills.
While The application that they have is massive and probably alot easier to formulat solutions for…they are also generating massive amounts of electricity.
The smart thing for you to do is research the right draft angle of most modern “getting off the grid” HOME windmills.
They are typicaly flat metal blades bolted to a flange.
Think of it like this…if you use say 4 layers of carbon (2 layers sandwiching a core material for stiffness) you can effectively double to triple the size of your blades and utilize more winds.
I think that there is a math formula that will tell you the blade size needed for X mph of wind to successfully generate power.
The beauty of carbon or hell…just plain old fiberglass (no real loads here fellas) is that you can open up the size of it to offset the weight penalty.
Thats the purpose of the new composite ones…to mimic the (danish???) skelotonized blades with cloth fabric (similiar to how they skinned old airplanes) keeping the weight down
Popular Science used to have plans on building your own wind generator.
I believe it involved some wood and a simple electric motor strung together with belts.
Good luck…Ive been thinking of doing the exact same thing. Ive not got the property to utilize it so its a back burner thing but Id be interested in hearing what you manage to dig up.
