ive got several molds which are virtually flat pieces and will be just cosmetic trims.
im wondering if it will work if i simply wet lay a single layer of carbon with gelcoat,let this all dry and then lay up 2 layers of glass with black resin and then pop out of the mold? sounds easy,im having no luck with vac bagging and these parts are very simple molds…
I don’t wee why not
if your resins are all wet, the pigment may travel through to the surface!
Other than that, I don’t wee why not eido
you can do what all the compaines doing from overseas and just spray paint the back
