Hi Everyone, I’m new to resin infusion so for my first infusion project I’m making a 12" x 36" 4 layer laminate using 9oz bidirectional glass cloth as the reinforcent. The laminate will be cut into smaller sections, each section will be used to create a 1" wide rectangular flange that will overlap several 5x7 square access holes (1/2" either side of the cut line) that I’ve cut in the wing of an experimental aircraft I own - the holes were necessary to access the fuel bays for some modifications. The aircraft was constructed primarily using Derkane 411-45 resin (later 411-R I think) so my question is two fold: (1) Do all vinylester resins bond well to other vinylester resins? (2) What brand or part number vinylester infusion resin would you recommend I use to create the above mentioned pre-cured laminates? The resin selection MUST be compatible with Derkane 411-45 in so far as the secondary bond using said 411-45 (bonding the flange to the inside skin of the wing and then later bonding the inside skin of the square cut-out to the flange) must be strong. Any advice you can provide would be much appreciated!
J
