Hi,
I am getting the urges to use carbon fibre soon, but want to make sure i am using the correct resin.
Can you only use Epoxy Resin for Carbon Fibre/Carbon Kevlar?
Can you use Polyester Resin with Carbon Fibre?
What is the benefit of using Epoxy Resin, is it stronger so you can use less meaning total weight is less?
How many layers roughly of what strength carbon fibre would you use for a racing bonnet, doesnt need to be flashy, just rigid, cheap(if possible) and light?
Thanks for your help!!
John
