which product from this list do you guys use as a gelcoat for your infused parts??
http://www.duratec1.com/ProductList.html#Duratec%20Products%20-%20Miscellaneous%20Applications%20
I don`t know about anyone else but i use 904-040 clear with no problems, just let it cure hard if using epoxy for your infusion.
I got mine from polyfibre, not cheap but it goes a long way
Baz
so its polyester based but it works with epoxy…would you say it is brushable? i dont have spray gear
Yep polyester, I`m sure i read a post somewhere by doogie that it was ok to use with epoxy as long as the poly had cured (probably get shot down in flames now) anyway i did a test piece and all seemed okay.
I dont see why you cant brush it on, its quite runny so you`ll need to apply a few thin coats. I use an HVLP gun with a 1.8 nozzle which lays it down perfectly.
Baz
i have an oil filled radiator in my garage (keeps the car warm in the winter soft ol bugger that i am) Then i just pump as much as i need into a mixing container and leave it on the rad for half an hour then add the hardener just before use, works a treat
Duratec is now owned by Rev Chem Plastics, but find your local dist. as shipping from Calif. might add to the costs. www.duratec1.com
If any one has a need for a pressure pot heater, a pressure pot with heater and top air powered mixer (I’ll covert the air mixture to use in 55 gallon drums with a longer shaft and more blades, unlike what I made a few weeks ago with a steel rod and welding big washers onto it which I had to take my air drill from the home shop to use) just showed up on my desk at school! It does have a BIG asp valve under the pot but I think I’ll convert the pressure pot into a degassing chamber but I have no use for the heater setup.
you can spray it out of a cheap Harbor Freight $15 spray gun, I would do that then brush it!
Doh i just phoned polyfibre up (twice) and they claim not to stock duratec :evil:
Any other suppliers out there?
they used to list it on thier site
problems,what kind of gun are you talking about?
these people are listed as a uk supplier, http://www.compms.co.uk/ give em a ring,ive gotta go work now
I tried there website after folllowing GGROPs link to the distributers but it didnt work but that one does!!! cheers!
Mikey, check with Polyfibre again because i recently bought some from them, it is listed in their Releasing,Cutting And Polishing section it`s called Durabuild surface coatings but is in fact Duratec and the cans are labelled Duratec.
Baz
cheers baznos ive ordered some from the company in the link GGROP supplied
Polyfibre stocks loads of stuff but this is the second or 3rd time ive had customer service problems with them but until i find a supplier for the other stuff… oh well
Cheers GGROP!!
Ive got to make a new mould now any way as ive just found two big chips in it :evil: guess im having a good day lol
how are you heating your epoxy ?
