I have a part that I don’t want to spend the time or money to make a mold of (mud guard for a mini supermoto), but I think for minimal effort I can clean the part up and do a lamination.
I wanted to see what the process people on tho board use for laminating. The way I plan to do it is to first, clean up the part and scuff with 80 grit sand paper. Second, I would brush on an epoxy resin and let it get tacky, once tacky I will apply a layer of carbon fiber. After the carbon is in place I would brush on an additional layer of resin. After it has cured I would sand and polish.
Is that the correct method? I have also seen people talking about vacuum bagging a lamination. What is the process for this? Do you apply a layer of peel ply and then put the whole part in a bag and pull vac? What kind of surface finish will this leave?
Thanks in advance!
Daniel
