Hey guys,
I’m having a little trouble with the infusion still. I took my time to do this infusion. Since all I could get in a pinch for vacuum bagging was the stretchlon 200, I put an extra layer of the stretchlon in top of the mold. Enveloped the whole thing and did a 1 hour drop test with no loss in pressure. I degassed the infusion epoxy for a good 20 minutes followed by letting it sit for another 10 min to let any small bubbles at the top pop. Infusion in the part went well, I slowed down the infusion through the mesh since it went fast. After the epoxy passed the part, I clamped the resin feed followed by the resin outlet. It looked perfect with no bubbles but after about 20 min, I came back to check on it and noticed air bubbles in the mesh which I assumed was normal. After 2 days, I opened it up to find bubbles in the epoxy (see pic at the top) and pin holes only in the section in the pic.
I was thinking maybe I had a very small leak, but the bag didn’t lose pressure. You guys think its time that I try the MTI hose? Or is there something I missed?
