What I’m trying to do:
Create an ID controlled tube with flanges on both ends. Later bearing cups will be pressed into the tube ends and seat against the flanges. I only care about the ID tolerance and creating a decent flange. The OD can be ugly because it gets processed later.
My strategy:
I turned a pair of straight mating mandrels (uhmw) on the lathe, fixed them together on a shaft, waxed, wrapped with CF, epoxy, peel ply, vacuum bagged, cured…thought i could pull the mandrels out…having way too much trouble getting the second part of the mandrel out. Like it’s not coming out.
What should i have done:?
I assume i should have tapered part of the mandrel…But is there a way better way to attack this?
Thanks,
-Kyle-
