Okay guys, as you can see from the pics the mold would not allow me to use infusion mesh over the entire mold surface due to some of the complex shapes.
The resin started okay but when the laminate was around 1/3 way I started losing vacuum on the inlet side, the bag became loose and resin flow slowed.
I may have saved the part, basically i waited until the laminate was saturated then switched the vacuum to the inlet side to obtain bag pressure once again.
what would cause me to loose vacuum pressure? how would I infuse with flow media around complex shapes?
Any advice on how to infuse this bad boy?
I have included one picture of the plug.
