So I wanted to strat my littje carbon project and started with a little practise…
I wanted to make a normal plate, just to find out how it all go with the vacuum etc.
I used a plastic plate, did some resin on it, layed up 3 layers of 200g/m2 carbon fibre (with resin in between each part) did a vacuum bag over it, turned the vacuum on (around -0,7 bar) and left it several hours on.
This morning I unwraped it, but there was no strength in it! The resin in the bucket (left over) was pretty hard. The resin on the product wasn’t sticky or something, but it’s just not strong
So… got it on the heater for a few hours this day, but when I came home from work, no strenght at all…
The product is nice and shiny from the resin though…
So the big question… What went wrong???
Could it be the temparature?? It was about 15 degrees in the garage.
The vacuum wasn’t on long enough? was about 3 hours on or so
Need to use more layers
Combination of the above?
Other…
Somebody help??
dont forget to lay the fabric in different direction,like plywood.
