What type of Resin?
I am going to be reinforsing an ABS interior panel on my car that has started to crack. I wasn’t sure if I should use an epoxy resin or a polyester resin. I wasn’t sure if the polyester resin would get warm enough while curing to cause the plastic to warp or if it would be ok. I’m leaning more toward the epoxy resin though. Any suggestions would be appreciated
For ABS you will have to use epoxy resin as PER will chemical melt the ABS.
