I’m looking at a Robinair 6cfm or 10 cfm vacuum pump. Both pull to 20 microns, but I’m wondering if I should invest in the pump with more cfm. All of my molds are 6"x12" or smaller and I wanted to run 5 at a time- possibly more in the future.
Is 4 cfm really that big of a difference when you are pulling vacuum on more than a couple of molds? Will the 10 cfm pump simply pull the air out of the bag faster, but in turn pull the same amount of vacuum because it is still rated at 20 microns?
Any help would be greatly appreciated.
Thanks!!
