I recently purchased some 4" wide fiberglass tape (according to the specs the stuff is similar to 10oz cloth) from Fiberglast with the intent of using it in lieu of manually cutting several 12 foot long 4" wide strips from a roll of style 7781 eGlass. To test the thickness of 1 and 2 layers of the aformentioned glass tape I prepared two test samples on a flat piece of glass. Test stack #1 was: peel ply, one layer 10oz tape, peel ply and test stack #2 was: peel ply, two layers of 10oz tape, peel ply. I used peel ply on both sides becuase I wanted to squeegy out the excess resin and get a realistic idea of the final thickness of the cured laminate. I used vinylester resin catlyzed at 1% for both samples… 24hrs later I peeled the test laminates off off the glass table and removed the peel ply and to my surprise I was able tear the 1 layer laminate about as easily as tearing a strip of cardboard box… yikes! And I can tear as easily in both the 90 and the 0 axis… The two layer laminate tears too but is a bit tougher. So my question is: Is this normal? I know for certain that I cannot tear a layer of my 7781 eGlass… at all. Do you think I purchased some inferior fiberglass tape? The application isnt structural but I do want it to be tough and tearing a layer by hand as easy as cardboard isnt my idea of tough…
Thoughts comments appreciated.
James
