As of about 2 months ago I had never attempted to make any composite pieces. Recently my job has had me making samples for destructive testing. I am having a really hard time making consistent samples, or even controlling the variability within a given sample.
Let me step you through my process, so you can point out where I may be causing the problems.
Starting with 2 waxed steel plates. I am using 8.7 oz plain weave 6" wide e-glass, cut to 8" long per sample.
Weighed out 20 gr of resin w/ catalyst, and poured onto the glass. Worked the resin around and in with the tongue depressor.
Placed second plate on top and secured with 4 c-clamps. This squeezes out the excess resin. I typically end up with fairly consistent thickness using this method. (.0115"-.0125"). The plates are put into an oven for 30 min. at 100C to cure. Pulled out and left to cool to room temp before breaking the plates apart.
The 6"x8" sample is cut into 1/2" wide pieces and then broke on the tensile tester. A breaking force, elongation, width, and thickness is taken from each sample.
My problem is that I am getting a very wide range of numbers for the breaking strength. The average is around 220 lbs, but the standard deviation is anywhere from 7 to 21, which is not enough resolution to detect any changes we make to the fibers with our coatings and additives.
Things we have tried that did not result in better/worse spread in data.
*de-aeration of resin after mixing
*Vacuum bagging, and use of roller to get rid of air bubbles/voids
*Mixing methods for resin
*Application method of resin onto the fiber
*Wet out time (time before I put it in the oven to cure)
Let me know if anything needs more explanation or detail.
