Hi, when is it not OK to wet sand parts (or use water for cutting)? I have a fair bit of sanding to do and I wanted to try wet sanding to reduce the dust. But I’m worried because I’ve heard moisture can have a detrimental effect. Some parts will subsequently be bonded, some will just be painted/clear coated. They are mostly fairly structural.
Thanks in advance.
