Wet-Layup questions with fiberglass and interior plastics
Having a problem with carbon fiber peeling over interior plastics. I know I can drill holes so the resin can go through the holes and act like rivets but I going to cover the plastic with fiberglass first then wrap with carbon fiber.
Questions
Will the color or fiberglass show through the weave of the carbon fiber??
Do I need to let the fiberglass and resin cure, then sand the fiberglass and primer it first prior to laying down the carbon fiber. Or will the layer of resin not stick to the fiberglass after I spray it with primer.
I’m trying to do a one of a kind custom job for shows and Advertisement for business.
Thanks for all you guys help.
