Thanks guys for your replies… I greatly appreciate it!
WyoWind,
I did a small test (emphasis on small) and it seemed to wet out, but I didn’t want to waste material on a larger actual production piece without hearing the experts on the forum first. I didn’t use any part of an intricate mold to do the test, so I wasn’t able to see if the Airtac2 dissolved or not.
Infusible,
Good to hear your reply… wet layup isn’t really normal practice for my business but in the past if I ever had to… I’d always wet the ply then put it in the mold. Unfortunately this new upcoming piece has some details that are very aesthetically critical and applying the carbon wet isn’t an option. I’ll maybe try ditching the Airtac2 for this one any try out your suggestion with regards to applying a thin layer of resin to the mold surface, thus creating a good finish surface and providing an adhesive for the fabric to cling to during the lamination.
Mugget,
I’ve never used resin to hold the fabric to the mold… Infusible from above mentioned that technique also. I think I’m going to have to try that out. Nice video you found, I remember reading a different post here on this forum recently with regards to the difference between “resin” and “pre-preg resin” as there is some sort of potential resin mix out time situation that could arise. Never the less, it would be interesting to make a pre-preg for non bagged room temp cure, I wonder if the outcome would be the same as if I had normally wet out the ply, but being pre-preg, allow me the opportunity to control the details of the fabric.
Thanks again guys, your suggestions, insights, and help are really fantastic!
-C
