Hi chaps, I’ve just got over my first stumbling block where I was trashing moulds from poor release… Thanks to Hanaldo and Elitec for that! So now I’m on to the proper job of actually starting to make some parts… if you can offer advice on how to improve my laminating from the below photos and layup description that’d be really appreciated!
PRF epoxy compatible gel coat
3 plys 200g twill carbon
PRF epoxy
Peelply
Bread wrap
Breather
Vac bagged 28.5in after drop test to find big leak
Damage to mould from poor release after buffing off semiperm like a wax:
Gel coat not wetting out as release agent working very well:
Gel coat released slightly before laminating:
Overview of moulded part:
Detail of air between carbon weave and bridging on external radii (ignore blotches in the middle from gelcoat needing to be brushed out again whilst tacky):
So my requests are for advice on how to achieve a better visual part using wet lay -
What can I do to get rid of the air between the weave?
- I brushed a layer of resin onto the tacked off gel coat, and wetted the Carbon between release film using a filler spreader before putting it in the mould. But despite this the carbon looks quite dry on the inner surface. Breather is quite wet, 2:1 resin to carbon ratio so plenty of the stuff slopping about, 3rd layer went in dry to wetted second layer.
What can I do to stop the bridging?
- I was quite careful putting the carbon into the mould, and after bagging I also went around with a plastic tool to push it into the mould. There is one tiny spot (less than 1cm2) that shows the peel ply bridged, otherwise it is carbon away from the gelcoat, like the top of the last photo. Should I conciously push excess carbon into the recesses of mould? Or should my peel ply be put in several strips to not pull the carbon away from the mould face?
What suggestions do you have to improve my layup process in general?
- am I using the right kit? Should I use a non perforated or less perforated release film like this rather than bread wrap?
Thanks very much for any suggestions!
