Weight Calculation
How do you calculate the weight of chopped strand mat with resin?
I can figure out my final weight if i knew how much 1 square foot of: 3 layers chopped strand mat 2oz, saturated with vinyl ester resin. Just enough resin to wet the mat. Non vacuum bagged.
I know if you vacuum bag csm/resin it uses much less resin.
Also how much does 1sq yard of 2oz mat dry weight? My scale is broken.
chopped mat weight is by the square foot, so 1oz mat is 1oz a square foot.
And about twice as much resin as mat. So FVF ~33%. So mat weight x3 = approx final weight.
Bottom line, heavy!
Thank you guys.
