I have been testing out this awesome product from Composite Envisions recently and I am so happy with it that I felt it was worth sharing my experience.
Weblock is the name they give to their carbon fiber fabric that has gone through their heat and pressure process. Unlike regular woven cf fabric, their Weblock material can not be easily pulled apart. You can’t accidentally mess up the weave when moving the fabric or pushing it into your mold. It’s pure genius!
I tried a 2x2 twill Weblock. It looks identical to every other 2x2 twill. You notice the first difference when you cut it though. You can cut clean lines without any of the rough edges and pulled threads you get with regular cf. it’s even easier to cut into custom shapes than prepreg.
No matter how much you poke and prod it in the mold, the weave remains intact so you get better-looking parts.
It costs $30 per yard instead of $20 but you only need it for the surface layer and I have made up for some of the price difference in reduced wastage anyway.
The downside is that it is a little stiffer than regular fabric so it doesn’t conform as well to tight corners. I was ok using it with good mold inserts to hold the cf in place but it took me a little longer to lay it neatly in the mold.
Composite Envisions are back in my good books again. I was mad at them last week because their epoxy tooling putty sucked and really disappointed me. This Weblock product more than redeemed them though. It genuinely changes things. Check it out if you haven’t already!
I would like to hear about the results others are getting with it too.
